Had a good read through some of the DIY threads on this and having seen the plug and play xcarlink adaptor I think I am going to collect up the bits required to fit a camera in place of one of the. Umber plate lights. The guides I have found relate to the fitting of the cameras to the saloon models of the Accord and obviously the Tourer presents its own set of challenges.
What I am trying to work out is where you would run the video cable?? As the camera will be fitted into the boot I guess the cable is going to have to run into the roof so would you route it along the inside of the headlining and then drop it down or is there a better route??
Thanks in advance and apologies for all these questions I keep asking!!
Si
Si
