Rob1n
Hi all, I am going to fit reverse sensors but the kit specifies that if the car has Can bus I need to fit a relay. My question please. Has my Accord got Can bus?
This is a part of the advert.
Technical parameters:
Power: 3.6W
Rated voltage: 12V Dc
[SIZE=small]( You may need to fit a relay to get power from ignition and using reversing light [/SIZE]
[SIZE=small]as switch only for some newer CANBUS cars as they can not provide 12v power [/SIZE]
[SIZE=small]from reversing light for the kit, relay is NOT included )[/SIZE]
Operating range: 9-18V Dc
Detecting distance: 0.3cm to 200cm
Detecting angle: H>60 degree, V>60 degree
