Running rich
Acercate
France
CL9 2007 Executive-E
Hello everybody,
I have a 2007 Honda Accord 2.4 and the problem is that my short term fuel trim is negative (-18%) causing my car to run rich.
If I switch off the engine (cold or warm) I have to wait a few minute before I can restart.
The idle is fine until the engine gets warm and the car will eventually stalls if I press gas unless I create a vaccum leak (Disconnecting PCV hose for example).
Fuel pump, fuel filter, sparks plugs, ignition coils, injectors, crankshaft sensor,...they have all been replaced recently.
I suspect a bad O2 sensor but I have no check engine light.
Any help would be appreciated.
I would go with changing both lambdas and also removing and washing out your cat.
On a much earlier Accord I used to own, the last exhaust box had collapsed inside, idle was OK but the car would run very rich at A road speeds.
Knocking a few holes with a poker up the rear pipe fixed it.
Good point, give the back box a tap and see if you can hear the baffles collapsed inside
The car has been almost fully restored. Everything is new from the exhaust manifold (4-2-1) to silencers (Fox Exhaust).
The previews line was a noisy single exit 4-1 without cata.
The problem was already there.
I tried to remove the exhaust or to unplug the 02 sensor to see a change. No difference except the noise.
Sensors have been tested comparing them to a clean 2.4 Accord.
All the values where exactly the same except the short term fuel trim. Mine is negative and never vary.
What about the fuel pressure regulator ? Is there any way to test it ?
Looks like my ECU is "Ethanol ready". That's why, using traditionnal fuel, I'm running very rich without any check engine light.
The seller "forgot" to tell me this detail...
