Hi,
I have set the settings in the Sat Nav options to "Auto" for Day/Night settings.
The manual says that if I turn the headlights on - the Sat Nav screen should switch to Night Mode. So I tried this late one evening - manually turn the headlights onto dipped - but the sat nav still remained on day setting.
However, pressing the brightness/contrast button on the front - does switch it manually ok between night/day.
I tried an updated disk - the problem still remains.
The time is set correctly.
What can be wrong? Is there a separate sensor for this?
(Auto headlights work ok - and the sensor in front middle of the dash ( by the windscreen) works ok too.)
:unsure:
Thanks in advance.
:unsure:
Thanks in advance.
