Accord-Brit
I have a fault with the new door that was put on the car while the respray was being done, the electrics don't work on it apart from door locking, I can put the window down from the driver window switches but i can't put it back up again from the same switch, I figured out I could put it back up from the driver switch if i touch a copper wire on the circuit board underneath the switch on the rear door though, also i can place the lock ont he door card down to lock all the doors but when i lift it now none of the other doors open again, this is linked to the new rear door too as it was working fine before...
So i know the electrics can work its not a motor issue its just a wiring fault, my guess is the wires in the plug connector between door frame and door are in the wrong places into the plug head ? as its not the same color's on each side of the plug, for example its not a blue wire goes in and a blue comes out the other side :huh:
Is there any online wiring diagrams floating about ? so i can see what color wires in the door should lead to in the frame too eliminate any wrongly places wires, It might even be because the donor door was from a newer accord or a diesel/sport instead of an executive, they might even be different on purpose i have no idea I'm just ***uming they are wired wrong atm.
