nick 9-5
So, the grinding noise that I thought was coming from the front wheel was actually from the back wheel and has been getting worse and worse so I did a brake inspection tonight and the pads and disc on the drivers side are knackered. I don't mind changing them myself, that's not the problem. What I want to know is what's causing it.
This was the inside pad that I took off
The middle ridge is about 2mm high and the corresponding disk is only showing clean metal within that strip aswell.
Any ideas or should I just change the discs and pads?
I pumped the brakes and the piston moved quite easily and went back in quite easily aswell.
