Shock Absorbers Removal Question
chesjak
south coast
Accord I-ctdi
Hi Guys
I am having to remove the front suspension upper arm and to remove the two bolts fixing it, I have to remove the shock absorbers to do this as they prevent me from removing them.
Instead of using spring compressors to help remove the shocks I thought I could undo the three nuts off the studs in the engine compartment holding the mounting unit in place and withdraw the whole shock ***embly which would make life simpler.
However, having undone the nut and expecting it to just drop down the unit will not budge even with a lot of banging.
Should it come away or is mine corroded on or something.
Any help appreciated.
Hi, there are a few vids on youtube showing this being done by just removing the bolts at the top mounting plus the strut brace.
Hi roadrider 75
thanks for a quick reply.
I'll have alook and see what I am doing wrong.
Many thanks
Roadrider 75
Easy when you know how!!!
I didn't undo the two strut brace nuts.
Just as well I had to replace the shock, it was really weak. It didn't show up whilst driving which was surprising. Did both to make sure.
Thanks again
