Side light removal
impne
Cold North East
Tourer type s
Any advise how to change these?
Not sure if mine are stuck it as they just won't budge
Lee do you mean the lamps or the hole light unit.
Just to change the bulb
Lee I changed mine when I brought the car for LEDs .
They just unscrewed easy from memory.
The lamps are 501 fitment I think and fits into the housing that unscrews.
I will check tomorrow lee and get back to you.
Tried that
Don't think they've been done before but still odd they are stuck fast?
Just a thought do you use your full beam a lot.
If so the side lights are under them so might have got hot and welded the housing
I don't but maybe previous owner did?
I'll mention it next week when it goes in again :)
This time to another garage lol
I think mine were stuck when I did them, you have to push them in a bit also, there is a rubber seal around the base. Squirt of wd40 might help.
Did push but nothing
Yep I'll give that a go tomorrow see if it works :)
