Slipping clutch on accord 7 i-cdti remap stage 1
tomas12345
sedan 7 2007 ctdi
Hello. I have accord 7 i-cdti saloon remap stage 1 and today my clutch started slipping a lot on 6 gear (full throttle) and a bit less on 3 gear. So right now driving on higher rpm to avoid slipping. If I remap again to stock 103kw, will it stop the clutch from slipping?
Yes it will lower the torque curve which might help it slip less but it’s not for certain. You have to be careful on the torque curve to ensure it’s operating within the drivetrain limits of this engine. A lot of tuners just max everything out.
Is it the same as if I put a brick behind the gas pedal so I could only push the throttle to 60-70% percent? :DD or is it better to remap to stock?
I would try the brick.
