Sluggish acceleration, high fuel consumption, stumbling start
YG--
Southern Germany
Accord CN1
Hi,
lately i've been chasing these issues with my 07 Accord 2.2 i-ctdi (around 400k kms)
Stumbling start - especially when its cold (but also sometimes when its warm) it tries to fire up but it kinda stumbles and you have to continue turning it over until it fully starts (a bit hard to explain i gotta admit)
Sluggish and sometimes random Acceleration.... sometimes it drives better sometimes worse but never 100%
Higher than normal fuel consumption (around 6l/100km)
following things have been replaced:
4 Injectors
4 Glowplugs
Timing chain
Turbocharger
Pressurerelief valve
been trying a few imrc solenoids out with slightly changing outcomes but at the end its still the same.
Cleaned out EGR and Intake runner fully
checked vacuum lines for leaks
what i noticed while checking real time data is; when under full throttle the car barely accelerates the target fuel pressure has no value... it accelerates normally when there is a value and it reaches the value when a value is set...
up for suggestions - located in Germany
Without any prior mapping to disable egr?
And where would u blank it? The piping from the cylinder head towards the valve or at the valve itself?
