dave0922
Evening all,
I am experiencing an issue that is rather annoying.
Basically, when I start up and leave for a journey, it seems very sluggish until up to normal temp.
Just to rule out the obvious, I have recently serviced every thing including the following:
1. New K&N panel filter
2. New fuel filter (honda original)
3. New engine oil and filter
4. New front and mid section exhaust
5. Due to MOT Emissions failure I have had a new secondary o2 sensor fitted
6. New honda ATF fluid (correct level)
7. Cleaned out the EGR valve and intake manifold plate
8. New spark plugs
9. New distributor cap
Now, there is a slight leak from the exhaust from the front end somewhere but cant for the life of me find where it is. There was originally a leak on the new front pipe due to poor welding but had it welded and seal tested afterwards.
So I am really confused as to what could be causing this sluggish behaviour at start up because it never used to do this?
Also, recently reset the ECU but made no difference. Once it is warmed up, it goes like the clappers.
Any idea's guys?
8. New spark plugs
Any idea's guys?
