Tomas have a look at the link it might help.
http://www.hondaoriginalparts.com/honda_car_parts_selection_pfk.php?block_01=17SEA01&block_02=B__0106&block_03=2848
Tomas from memory the air intake should come from the bottom of the air filter box down to the resonator.
Then turn up in front of the grill with another pipe to let air in if that makes sense.
So are you saying there is something missing like the pipe from the resonator.
Tomas if its broken you will notice its loader.The pipes and resonator are just a push fit so it might be just a case of pushing it back together again.You might get better access to see if you remove the battery as well.
