Hi all,
I’ve been reading the forum for over two years now. Never actually got to the point of starting a topic. Probably because it was needless, I’ve always found solutions for my issues already on here. However this time I didn’t find anything accurate. I’ve had my accord for a year and a half. Not many problems with it, apart from injector seals. 3 out of 4 was changed over this amount of time. I was going to get the 4th one replace but my mechanic couldn’t get the injector out. He put the clamp and bolt back in how it should be. Not even a week later I had my injector popping out. It ripped the thread out from the cylinder head and the bolt is snapped too... I’ve had the thread ripped out before with another injector, that’s been sorted by a specialist (they put an insert in) and still works fine. Question is what is the best to do in this case? Forgot to say the engine is young 126k on clock unless it’s been rewinded (not sure if it’s possible). I don’t know if the car’s been remaped. Anyway these things shouldn’t happen either way. Thank you for all the help in advance.
