edgeoftime said:
I bought a Jazz from an importer, it was Japanese built and the speedo was in KMPH, however to conform it had to go to some UK CONVERTER WHO RECALIBRATED THE SPEEDO TO MPH, and the motif was modified to read MPH by removing the K also the radio had to be modified.
The official requirement for an mph speedometer on import vehicles is dependent on age. If it's under 10 years old it'll need and IVA/SVA (whatever it's called these days!) to be registered here and part of that test is ensuring that the speedometer reads out in mph. If the car is over 10 years old then there is no requirement to convert the speedometer to mph from kmph as the vehicle only needs to pass an MOT prior to registration.
When being converted to mph the actual gauges aren't recalibrated as such, on modern cars with an electronic VSS the standard method is to splice in an electronic device which alters the signal to trick the dials to read low. It's not ideal though as it often causes the ECU to think the car is going slower than it is which can result in some side effects, for example in VTEC engine JDM Preludes you often lose VTEC in first gear as the ECU doesn't think the car is travelling fast enough for VTEC to engage... The best method with regards to retaining OEM functionality is to obtain replacement dial faces and have these fitted. There is always a risk of damage to the instrument cluster during installation though unfortunately.
RE the radio, they use a different bandwidth in Japan so without a frequency expander all you will pick up is radio 2. An expander is about £15 off of ebay and gets wired into the existing aerial feed.
ady_uaic said:
understood. I know that I'll pass the MOT, but I need it for me (now I'm calculating every time in my head - 50mph x 1.6 = x/kmh).
I don't want to convert km to mph, but just a quick swap of the dial
fwiw I didn't convert the speedo on the Subaru I had recently, and it only took a day or so to learn the relevant kmph speeds. No need to work them out each time, just grab the equivalents to 30, 40, 50, 60 & 70 and revise them for a little bit. It will be second nature before you know it!
Alternatively you could contact a company such as Lockwood, I believe they can make custom dial faces if required. Be prepared to spend a couple of hundred quid plus fitting though!
