I have been discussing this on another forum, thought it would be good info for here also.
Basically, its the very basic fundamentals of working out spring rate. (prerequisite is you know the stock spring rate.)
So for example if your looking into a 2" drop and want to know what springs to run.
As a rule of thumb, you want to increase the spring rate to "counter" the loss in suspension travel.
So for example: say the stock travel is 8" with a stock 225lb spring
with 2" drop you now have 6" to work with.
so you want to know how many pounds per inch,
225lb/8"=28lb/in X2 (2" drop)= 56lb increase from stock which = 281lb spring.
This is works out to be 25% increase in spring rate.
which is exactly what 2" is of 8", 25%.
But this is still a soft spring in reality, and you can run upto double that rate but then youd would need to look into dampers, which im not covering.
Hopefully this is helpful/understandable
(this ***umes no change in dampers rates)
