chesjak
Every so often when I flash the headlights they stay on.
I have traced the problem (I think) to the solenoid situated in the same box as the fuses under the bonnet.
It is actually under the fuses and to get at it as far as I can see, you have to undo two electrical connections at one end of the fuse box before you can lift it off.
If I do this will I upset any electrics in terms of settings etc or can I just put it back as normal with no problems.
Any help appreciated as always.
Regards
Regards
