YES I HAVE DIESEL CAR 2007 2.2Hello. Clutch could be worn but without more details really cannot say. Do you have a diesel?
Also have you complete drive from the car?
OK BUT IF CLUTCH SLIPPING WHAT CAN I DO AND HOW MUCH COULD BE HAVE??It certainly sounds like a slipping clutch to me.
!00 % clutch slippingYES I HAVE DIESEL CAR 2007 2.2
WHEN I DRIVING LOOKS LIKE NO PROBLEM JUST WHEN I ACCELERATING AND PUSH THE GAS PEDAL BIT STRONGLY!
yes !!sorry!!00 % clutch slipping
Can you take the cap lock off as capital letters is very off putting.
Have a search in 7th gen diesel faults all will be reveiled there.yes !!sorry!
slipping clutch how much could be have to fix it?
Torque and lots of it. It's the payoff for wanting diesels that perform like petrolswhy do clutches go on diesels?
2007 is not exactly old, is it due to very bad driving on honda owners part or bad clutches fitted in the first case?
The root cause is the high torque output... not a problem in itself (actually quite a good thing!), but then Honda never made a clutch fully capable of handling that amount of power, even after 3 attempts (part numbers ending in 305, 315 and finally 325). Sometimes this situation is made worse by a poor driving style (i.e. hoofing it at low revs, rather than changing down) and obviously the popular option of performance remapping puts even more load on an already weak clutch. And we diesel owners are also burdened with the need for a dual mass flywheel (DMF) necessary to smooth out the engine torque pulses... this also wears out and often has to be replaced at the same time as the clutch. Honda generally accepted they let down their customers and did eventually gave an extended 7 year/125k mile warranty.why do clutches go on diesels?
