Freeloader150
2007 2.0 EX Tourer
I Have an issue with the sunroof causing water to leak into the headlining.
I've removed the headlining and checked all the drain outlets [they appear to be allowing water to escape]. Water is spilling over from the drainage channel in the sunroof ***embly and running along the headlining until it can find a place to escape [plastic trim above the nearside rear window].
The car is parked on a slight slope, although sometimes the leak isn't apparent until the car is driven and water runs back.
Anybody had this problem or know what's causing it? Any idea for a cure would be appreciated.
