old cruiser
Guys am I missing something here with the sunroof; basically today is the first time I've used opened since I've owned the car, what I find is that when I tilt it up by pushing the button in the roof lining upwards, it tilts up no problem but for the return it appears you have to slide the switch backwards and as it drops it then seems to slide open and then have to slide the switch forwards again to get it to settle in the closed position, seems to be no way to just drop it from tilt without it sliding back etc. if that makes any sense!!
I also notice the rear of the sunroof seems to sit a little lower at the rear than it does at the front when it's in the closed position, maybe typical of these roofs?
Cheers Pete
Cheers Pete
Cheers Pete
Cheers Pete
