Hi guys
I have a 2006 ICTDI Tourer today while doing my tyre pressures something caught my attention around the steering rack boot on the drivers side, at first I thought it was PSF but when I looked further it was definitely engine oil, it was in the grooves on the boot for about a inch from the rack end it is also present on the frame under the boot and a little further forward, I chased the trail all the way up to the top by this time I was under the bonnet, I could see it down the side on the timing chain cover and on the small pipe that comes out of the block just under the top engine cover under the oil filler cap, at this point I am quite concerned, first job check the dipstick oil was where it was last time I checked it, next job get me hand in there with a clean rag now when I wiped some off it was definitely engine oil but it was clean engine oil, I had the oil and filter changed about 3 weeks ago could I be thinking right here that there could have been a spillage on filling and it's run down and flown about a bit, so I have cleaned the area up with de greaser and will have to see what happens,
Any thoughts on this one.
