wahabishtiaq
Hi All,
Hope you are well.
Today i did MAF sensor clean with change of engine cover bracket (attached to swirl valve) Also had LED W21 rear tail lights changed to LED's. After i re ***emble everything and restarted the car ignition coil sign starts blinking on dash board along with EML sign on MPG screen with Exclamation. However the actual EML above RPM is not on. I took car fro a drive test and no obvious sign of missing or hesitation, also during this drive the ignition coil light was blinking on dash board.
Any ideas what could have gone wrong, or any issues due to the work i completed. I will get this code checked on Snap on but obviously any advice or knowledge will help to preempt the issue.
Many Thanks
Hope you are well.
Many Thanks
