System error
wahabishtiaq
Hemel Hempstead, Herts
Honda Accord 2006
Hi wise men,
Today I came to know that my 7gen diesel don't have spark plugs which was a surprise ( because I never knew this before)
When I turn the key on the lcd screen an amber messages shows "check system" and when car is started it quickly disappears.
If there is no spark plugs then what could be the reason of this message.
Your opinion will be appreciated.
Diesels are not spark ignition. They do have glow plugs to pre heat the fuel on start up only. The glow plug indicator(orange coil) comes on for a few seconds when you turn the ignition on. I cant remember the system check but if it goes out when started that would suggest all is well and only a self check.
depends on the size and purpose of the boat it's in
https://www.youtube.com/watch?v=1dr011-s-Ig
Aye mine flicks up system check for a split second on start up. It's a face lift 7th gen diesel. But got no problems.
you ought to check with a Honda HDS on the OBD (an ordinary OBD reader won't read the ABS)
Mine some times flicks up check abs and sometimes flicks up check system only for a split second,but has done this for nearly two years since I've bought it. and have had no problems.
