I have a 2006 Facelift 2.4 EX Estate with the power tailgate.
The Tailgate Open light is lit on the dash (the one which is on the bottm of the small car picture).
The tailgate opens and closes fine both manually and with the power open and close.
However the car wont lock on the keyfob and the interior light in the roof stays on.
I can lock the car by using the drivers door switch then closing the door. It will then open using the fob ok but not lock.
Im ***uming the issue is the switch or sensor that senses whether the tailgate is open or not.
I cant see a convential push in switch like the doors have. I have done some googling and there appear to be some sensors around the edges of the tailgate under the seals. Is it one of these that could be causing the issue and how do test/gain access to them ?
Anything else i shoukd be looking at ?
Cheers in advance
David
Cheers in advance
David
