Temporary alarm fix
Richard B
Australia
2006 Tourer
The alarm backup battery finally died. Got the alarm out by removing the subwoofer, taking a flash photo of the installation, and unbolting the Cobra unit from there. No need to remove all the panels like a lot of people say on here.
I thought about replacing just the 6 250BVH Ni-MH cells, but the shrink wrapped full replacement sells for little over same amount. Also, larger Ni-MH cells are much cheaper, and I would prefer a larger backup, but I cannot find much info on the current regulation in the charging system of the Cobra unit, so 250mAh it will have to stay. If anyone has DYI'd something like that, they haven't posted about it online.
I need to use the car before the battery arrives, and I want the red blinkenlight in the dashboard when I park, so a bit of reading on Cobra alarms in general, and I saw that other Cobra units actually work with the backup battery removed.
So I tried that, and this is the case with the Accord alarm as well.
I then used this eleven year old post on Typeaccord to reset the alarm. Brilliant.
Post in thread 'Reset alarm'
Anyway, 2 things learned. One only has to remove the subwoofer to repair the alarm, and it works without a backup battery, as a temporary fix.
PS. Wrap the.alarm unit in a blanket white you do the reset. Then bolt in back in place.
There should be no problem fitting a larger battery on the same charging connection. It it can be done in mobile phones and laptops then a car alarm will be no different.
There should be no problem..
Yes I think you're right. NiMH charging is the same as NiCD ISTR, and chargers for those didn't seem to mind what capacity battery you attached. A 4x capacity pack is 10x cheaper, as the original BVH cells seem to have very high capacity per volume. I'll just have to mount the battery externally (no problem where it sits).
