I've noticed a number of people are having trouble with water leaking into footwells and the question of door seals and membrane comes to the fore.
When I purchased my car I had problems with all 4 door seals leaking and it was only 18 months old ???
The mechanic at the dealership showed me how they test the seals membrane and drainage in the doors it's quite simple.
Firstly open the door so you can see the inner of the door and the drain holes
Get a container (bottle) of water.
Pour the water down the outside of the door window.
Observe the inside of the door the water should only come out of the drain holes. If you see water coming from any other area at the bottom of the door then it's a good sign that there's a problem with the membrane inside the door. Probably come unstuck.
I think someone has posted a good thread on how to repair leaking membrane so put both together and you have a solution.
Hope this helps people.
