scubatricky
Just noticed a puddle today under the Tourer, 05 Plate. It's been parked for a few days, and when I lifted the bonnet to check oil level it appears the nearside (auxiliary belt end) is sprayed with black engine oil, as if it's being picked up by the pulleys and flicked down the pulley side of the engine; it's over the abs block, washer bottle cap and drivers side headlight back.
I've debunked the engine, pressure washed it and removed the lower plastic engine protector, and inspected the underside (suspecting drain bolt or similar).
The oil appears to be coming from behind the crank pulley (large lower one on the end of the crank shaft). I'm guessing there's a big oil seal hiding behind there and it's now given up?
Main question is; Is it hard to remove this pulley and replace the seal as a DIY? If not, what can I expect to pay Honda for the privilege. I'm guessing the seal doesn't cost a great deal, but the labour will be the painful bit.
The car is on 180,000 miles, and other than this its still going strong :-( Any advice and help much appreciated. A little annoying after throwing £1300 at Holdcroft to do the clutch last year (boo hoo)
