I have schockingly noticed that my 2003 Type-S 2.4 doesn't have an engine under tray. The nearest I found is from a diesel. Does anyone know if they are the same or will it fit, does it needs modification to put it on?
I was looking through the car instruction manual today and also discovered that my car was supposed to have an under tray.
The diesel and petrol trays look similar enough from the manual, both having the oil drain access door in more or less the same position. Annoyingly, the manual shows the procedures from 2 different angles so I can't tell.
