GAZB
Last night I got a warning sign flicker on after a few miles of driving , it was a circle with squiggles at the bottom of it , it went off then around 5 miles later the VSA Warning lights come on , stopped car turned ignition off started again all O.K with no warning lights on then after around 5 miles it did exactly the same again , turn ignition off , start up and all O.K again for 5 to 10 miles then warnings again.
Will this be the pump or a sensor , was thinking if it was the pump would the VSA warning lights be on all the time
