Grayedout
Just to add to my current issues then now having VSA problems!
Twice in the last couple of weeks I have been taking shallow left hand bends at speed but nowhere near the limit of adhesion and the VSA warning light has started to flash.
It did it again last night including the VSA actually applying the brakes (quite harshly) but then the Warning triangle VSA light stayed on!
Not had chance to start it again to see if the light has stayed on but where do I start to look?
Had a read through most of the VSA threads on here and seen possible fixes being clean/replace brake switch, replace wheel sensors and the expensive VSA module change!
If it was the sensor then should I also get ABS warnings?
If its the VSA module then does this also handle the ABS or is this a different module?
