Hello all!
My left hand drive 6th gen Hatch has several water leaks; In the boot ( spare tire area and on both side floor panels, under the fabric lid ), in the rear footwells and the drivers side footwell. I was about to give up but decided to try to sort it out.
I know the rear taillights were leaking through the gaskets, and I have ordered new ones. Tried to re-seal the old ones, but not good enough. I also noticed the car leaks onto the top rear strut mounts, and the car is also wet under the top of the headliner, near the hinges.. It was also wet just underneath the rear washer jet, but it is IMPOSSIBLE to get to! I can see the tube going in to the jet, but no way to get my fingers in to fix anything there. I suspect it leaks somewhere in that area ( jet or hinges, or both... ) and that the water runs through/down through the inner panels and onto the rear strut mounts. From there it goes both to the front and rear of the car...
The rear footwells are also wet under the carpet. I just dried up a small puddle underneath the rear drivers side footwell. I also just noticed it's soaking wet in the drivers footwell, especially underneath the dashboard insulator. I could see a trail of "rust" and water coming from above somewhere, near the "corner", just in front of the fuse box.
I have ripped out everything ( except from the dashboard insulator - will work with that one tomorrow ); seats, carpets, linings... Has anyone experienced something similar? I know it's a big process to try to figure out where the water is coming from, but at the moment it seems to come from everywhere. Seriously need some help with this!
Does anyone know where the water is suppose to drain? Where the trail is, in lack of a better word? I just want a dry car... So any input from you guys will be highly appreciated.
Kind regards, Knut
Norway
Kind regards, Knut
Norway
