Vasco Reloaded
Hello all, since an h22a7 is a dificult and expensive swap, i´m considering a low boost turbo setup for my accord. The reason being that my car is imaculate, everything looks nice and if i try to sell it no one is going to pay what it´s worth for me.
So i was thinking of fitting a turbo to it´s FB206.
Mechanical part is easy because i have a friend that´s used to to these mods on n/a diesels, basically when he can´t find a part like a manifold of a mount he makes them himself, so the actual mounting won´t be an issue.
The issue is electronics, i don´t understand much of what do i need to buy, in order for an aftermarket ecu be able to run on this engine.
- Can you give me links to all parts i need to buy?
- After buying, i ***ume the new ecu doesn´t have a program, how do i extract the setup from the original ecu to upload to the new one, or where do i download a setup that makes the car run, even if it needs later adjustment?
Thank you in advance.
