Ok while changing the high pressure steering hose I noticed I have a slight weep on a hose that's connected to a metal outlet located behind the block near the top under the oil filler it connects to another metal feed just below the rubber part is only about 8 inches or so, it looks like it's weeping on the top joint it's held in place with a hose clamp at each end, it's about the diameter of my index finger. Any help is appreciated
