edgeoftime
The windscreen washers on the car are not as powerful as they used to be, I read that the motor maybe failing but it sounds the same as ever it did, I suspect the jets, but how do you clean/adjust them? the hole appears to be clear (needle poked down it) there is a screwdriver slot? what for. Also how do they remove from holders, I see that by pulling back the right side inner wing I can get at the motor, and remove the pipework to check for blockage there. Sorry if I have answered my own question, but maybe someone can "simplify" the problem.
