Bad news. Honda UK confirmed today they will not be covering my car under warranty. As such, I will now have to pay for the timing chain/injectors to be replaced.
Sickeningly, this will probably mean I will be putting my car up for sale after the work is completed, as my total spend will be far more than my original purchasing budget. I will be ringing around a few places for prices on parts and labour.
Does anyone know is there anything involved in the timing chain replacement that would require me to have the work done in a Honda dealer? I have a local trustworthy mechanic that I use from time to time and I will be asking him for a quote on the work. From a previous post, I believe this is the total list of parts -
CHAIN (118L) (DAIDO)
TENSIONER ***Y,CAM CHAIN
SPROCKET, CAM CHAIN DRIVEN
CHAIN(58L) (DIDO) TENSIONER ***Y., OIL PUMP CHAIN
SPROCKET, DRIVEN (18T)
SPROCKET, CHAIN DRIVE
PIPE COMP., HIGH PRESSURE (#1)
PIPE COMP., HIGH PRESSURE (#2)
PIPE COMP., HIGH PRESSURE (#3/#4)
PACKING SET, HEAD COVER
GASKET, NOZZLE.
BOLT FLANGE, 12X87.
BOLT, FLANGE, 12X100
BOLT, FLANGE, 12X75
BOLT, FLANGE, 12X45
BOLT, FLANGE, 12X38.
NUT, FLANGE, 12MM
O-RING, 8.8X1.9
WASHER, SEALING, 16MM
BOLT, SEALING, 16MM
INJECTOR ***Y. Quantity 4
If anyone knows what sort of money the timing chain kit etc costs, can you please post? I would like to have an idea so I'll know if I'm being ripped off. Also, I've been told by a Honda dealer that the work takes 8-12 hrs. Is this correct? Thanks for the advice.
K.
