Remember there are 2 main types of ICE builds these days, SPL (Sound Pressure Level) or SQ (primarily Sound Quality based, flat EQ, volume levels are far far lower but faithful reproduction is the key). This is more towards the SQ kind of build, but with added balls, so crystal clear clarity and fairly decent volumes with a good dollop of tuneful bass. By that I mean basslines are followed with some accuracy albeit at fairly loud levels. Lots of cars will go louder, but they certainly won't sound as clean as this does across the frequency range.
So the good news is it's finally finished. Well kind of. It's all in fitted & working but there are a few cosmetic bits needing attention. These will all get done over the next couple of months as it gets warmer, and are already paid for etc, it's mostly just a question of tidying up & finishing off.
1) A Battery Box for the boot install needs to be made from sheet aluminium & carpeted.
2) Under Rear Seat still needs to have the Silent Coat applied.
3) A custom fit Perspex Panel covering the Amplifiers needs to be made & fitted, with JL Audio Decals.
4) Re do Amp Rack. I'm going to hide away the cables underneath. Quite a rigmarole but will tidy the look up.
5) The temp Ski Hatch needs finishing off so it's visually perfect.
7) Driver's cubbyhole has 2 bass controllers in and the infra red control for the TV tuner, so it needs a mounting plate cut & custom fitted to tidy it all up inside.
6) Courtesy LED's in front doors & footwells.
So how does it sound? Initially it was impressed, then maybe a little disappointed. Then a few crossover tweeks, measuring path lengths to my ears in my driving position, time alignment dialing in and corssover adjustment then it was just like WOW!! We have CD, Mp3, iPhone, DVD, Freeview TV, DAB Radio, Handsfree Bluetooth & Reverse Camera. Oh & Sat Nav, I nearly forgot that. There are 11 Speakers, 3 Amplifiers, & one very happy driver!! A good week or two running in the speakers inside the cabin, then more gain levels & crossover tweeking, & finally then some EQ to my own personal preference (which is totally flat so far).
Here is a system diagram with how it all eventually ended up.
So what is in the install?
Pioneer F-60DAB Head Unit/Sat Nav
Alpine TUE-T150DV DVB-T TV Tuner
Alpine KRE-500E Remote Eye
Alpine KAE-210DV Amplified DVB-T Tuner Aerial
JL Audio 1000/1 Amplifier (driving)
JL Audio 12W7-3 Subwoofer
JL Audio 300/4 Amplifier (driving)
JL Audio C5-650 Dash mounted Tweeters
JL Audio C3-650 Front Component/Coaxials
JL Audio A2150 Amplifier (driving)
JL Audio C2-650 Rear Components
Pyle PLCM HONDA Infrared Rear Camera
Silent Coat Bulkpacks 3x2mm & 1x4mm
CCF Self Adhesive Decoupling foam 9mm & 3mm
0awg Power & Ground Cables
4awg Power & Ground Cables (Sky High)
0agw & 4awg Terminals
Plastic Conduit trunking
KnuKoncept 0AWG Battery Terminals (2 sets)
KnuKoncept KNF-60 Fused Distribution Block
KnuKoncept KNF-36 Fused Distribution Block
KnuKoncept 8AWG x2 Subwoofer Cable
Technical stuff
After a quick listen to 2 of JL Audio's official demo cars, my original plan to use the C2-650 Speakers as my front had to be changed. As with all manufacturers there are base model speakers, then as prices increase as does the quality & the technology along with performance. The C2's retail at around £150 now, (£190 when I bought them), and although they are a step of from the Alpines I had in the Lexus, they then were clearly outclassed by the C3's.
The C3's are an interesting engineering solution. They are a convertible coaxial/component system, so in effect they can be used as a drop in speaker replacement with the Tweeter mounted inside the front of the Woofer like this....
or they can be detached (literally unscrewed) and run separately as a Woofer & Tweeter and mounted in separate locations
leaving the Woofer with a supplied phase plug
They have an externally mounted crossover to split the frequencies between the speakers in either mode
JL Audio ran these with the tweeter attached in their demo cars as they feel it provided better imaging with the drivers closer together, and after listening I had to agree. They also ran in the centre of the dashboard another set of tweeters to help lift the sound more up to ear level, in a ghost tweeter arrangement. As I wanted a stealthy look I decided to do this with the incredibly HQ C5 Tweeters, but hidden in the stock locations in the far corners of the dashboard. This has worked out incredibly effective, as although they are running at approx 3dB lower than the C3's, it is just enough to raise the vocals up to head level, & tbh with them seperated the soundstage imaging is pretty awesome even if I do say so myself. The C5 Tweeters & adjustable crossovers, note the jumper bars for adjusting the tweeter volume so they integrate as needed.
C2's (originally going in the front)
So the C2's got relegated to the rear doors, these only run for effect when I am alone in the car, so are backed down to around a third volume to just provide something known as rear fill. Only when I have rear seat passengers in demo mode they get some more volume. The sound should always come more from the front as you simply don't go to a concert, & then turn your back on the main stage.....They still sound pretty awesome but are outclassed by the newer C3's in the front door. As my 300/4 was now running in 300/2 mode, the C2's power demands are provided by another JL Audio Amplifier; [SIZE=14.3999996185303px]a A2150 (eBay you godsend), which takes up every inch under the driver seat & provides up to 75Wrms to each rear door.[/SIZE]
Not any room at all under the drivers seat now lol
So a few bit's and bobs to do over the next month or two after it's all given a final dail in, but thankfully spending money is now over, which is lucky really as that coincides with me having none ha ha
Anyone local to London that just wants to hear a demo, message me as I will be at a Lexus *(cough cough) meet towards the end of February in NW London, or just PM me and we can sort something else out that suits you.
