Managed to do a bit more work on the install on Monday. Firstly there was "Upgrading the Big Three"
OE car wiring is built down to a price, and is also built to a certain spec. Car manufacturers will build to a price point/standard, but if you imagine how much wiring they put into every car, even small savings of a few pence add up to millions of £££'s over time. Copper cable is expensive, the thicker the cable, the higher the cost per foot/metre. Cars are not designed to have aftermarket goodies added to them
Take the earth straps in your engine bay, they do an important job if engine/gearbox to chassis & battery to chassis. If you have ever had earthing issues of one form of another, you will already know how important a solid earth is to the cars electrical system. Bad earths can lead to all sorts of malfunctions, one of the most common is radio interference, or rear light clusters going crazy.
Over a period of time copper oxidises in contact with air causing it to corrode, also after many years of vibration wires can also fatigue. They may not totally break, but fatigue or corrosion can cause the performance of the cable to become severely compromised as time passes.
This can cause loss in your electrical systems efficiency, the battery might not get as much charge as it should, the starter might not get as much current as it should so turns slower causing it to take longer to start, the spark plugs could get a weaker high voltage (more so in older cars but you get the idea)....
The really important earths are Engine/Battery Engine/Chassis & Battery/Chassis. There are lots more but for simplicity sake we won't name every single one. By either replacing these earths, or adding additional earth cables in these distinct areas, the theory is you will help to bring your cars electrical earths back up to or even better than (more of this later) it was when it left the factory. When you install a kit like this an essential is a small wire brush to take off any corrosion back to bare metal, or if a supplementary earth, to take paint off back to bare metal. Obviously you don't do this where rust would result etc.
In ICE thinking, "The Big Three" takes this a stage further than just upgrading your ground cables.
Additionally upgrade or replace entirely......
1) Battery Ground to Chassis
2) Battery Ground to Engine/Gearbox
3) Alternator to Battery Positive
In ICE, especially at the performance/competition end, an efficient electrical system across the board is essential, but as a first stage the Big Three is normally a first step to gaining better performance/efficiency. BEFORE adding more batteries or capacitors or bigger rated alternators etc. so get the best out of what you have FIRST, before spending additional funds where it might not be otherwise necessary. So using as big a cable you can afford & that will fit (4awg is a decent starting point in ICE terms, rising to 0awg or bigger for big ICE), run supplementary cables in these vital areas to improve performance. The difference is quite marked. I did the big three on my Honda on Monday, 13.8 was across the battery at idle, it is now 14.11. Proof in my own eyes that the theory works in practice.
Way back on my Lexus I did notice marginally better starting (& it wasn't a bad starter to begin with) and a smoother idle. I also got better Radio reception than previously. On the Honda the idle seems smoother too, but maybe that is my mind playing tricks on me.
I hope what I have posted makes sense, I'm no expert/professional but have tried to explain the theory as best I can after years doing ICE as a hobby & all information is correct as I understand it.
It was damn hard work continuing the install, as has everything else ICE related been with this car, but think we are turning a corner now. I forsee only one problem regarding getting additional wiring into each door, but I will cross that bridge when i come to it. Anyway here are the pics.
1 Remove Stock Battery & then the undertray to give better access for running the Alternator cable
2 Oawg and Braiding
3 Battery Terminal and Chassis Earth Upgrade
4 I'm not a pro but that will do
5 O gauge & Conduit for Alternator & under the car
6 Extra Alternator Lead to Battery. The 0awg ring terminal was slightly oversize to fit on the stock alternator, so had to have a little dremel work so it fitted snugly.
7 Alternator Lead in conduit
8 Insulated bracket spur to avoid chaffing of Power lead.
This is at the side of the engine cover, and would otherwise chaffe the Power Cable over time.
9 Conduit Heatshrunk to Braiding
10 Positive Terminal
