knucii
Hi all,
So it has been 14k miles since I bought my lovely pre-face lift 05 plate accord and today on the way to work I ran into some clutch problems (it now is at 114k miles and there was no service book so I don't know if the clutch was ever replaced) (((. The clutch pedal stop properly doing its job did and once pressed down it would not properly come back up. luckily this started happening within 0.5 distance from my work and I was able to make it there by somehow engaging the 2nd gear.
I checked the clutch fluid levels and they are ok and there did not seem to be any leakage so I would say the fluid is still there. The fluid was replaced some 8k miles ago. I tried starting the engine and engaging the first gear: i pressed down the clutch pedal and slotted the gear OK but once starting to release the pedal it wasn't properly coming back up and then the engine just stalled ( I would ***ume the clutch engaged in full too suddenly)...
In either case I had the RAC come and rescue me. The guy asked me to hit the clutch pedal several times while he was looking at the clutch cylinder and then he pretty much very quickly identified that its the whole clutch that is at fault and needs replacing. He tried to explain what the problem was but me being me I didn not understand all too much...
So before I go and spend £1000 on the clutch change I thought that I'd come up here and ask for you opinion. Any help would be appreciated. I also know that the clutches of these accords fail in a different way so that is also suspicious. I just bought some dot4 and will replace the clutch fluid to see if that helps.
Cheers!!
Cheers!!
