Hi this is my first post.I have a 05 2.2 ctdi which i have owned since new.About a month ago i filled up at at supermarket,very rare for me,so i used some diesel cleaner.About 3 weeks later shortly after setting off in the morning i went to accelerate in 2nd from low revs and it was very sluggish,the revs built up and all was ok.this happened a few times in the next week and a short lack of acceleration has continued intermittently.After not using the car for 24hrs the car started with extra smoke but did not want to rev cycling up and down until eventually getting back to normal,and is now slowly getting worse.I work at a honda dealer and watched a techie do all the tests with the hds and the only thing obvious was high fuel rail pressure.We decided to replace the fuel filter as a first step but to no avail.Like most dealers only genuine parts are fitted so it seems that to keep costs down its down to me to sort out things from now on.I am ***uming that the most likely cause is around the the fuel rail in the relief valve or pressure sensor?. Am i barking up the wrong tree?I am not a technician but can get help from the guys at work. I have read the article on relief valve testing and was going to do this first unless someone can say this is not the way forward. Does anyone have the bosch part no for the relief valve? All help much appreciated.
