FRVAC
I have recently joined the forum. We purchased a 2007 diesel Accord Tourer a couple of months ago. Please excuse what is undoubtedly a very long first post.
I own two cars with i-ctdi engines, the other one for about 18 months now. I've been unclear about the oil grades all of that time, during which I ran ~6000 mile change intervals on 0W40 because it appeared to be within spec. Now the "new" Accord is coming up for a change.
I have noted that members here, in line with the handbook, recommend 0W30 as do other fora I have consulted. I have also looked at the Opie Oils website. Recommended oils appear to be Castrol Edge, Motul, or Exol as well as Lubetech. All these are 0W30, but A3/B4 grade. The handbook however recommends a B1 grade, while indicating that 0W40 (B4) and 5W30 (B1) are also acceptable amongst others. My questions are:
- if a cold 0W40 oil is of similar viscosity to a cold 0W30, and a hot 0W40 is much thinner than a cold 0W30, why would there be a problem using 0W40 (other than reduced economy) if the engine is never used at its limits?
- if (as I presume) the car could be run on 0W30 in midwinter in a very cold northerly climate (eg Greenland), such that the 0W30 would be as thick at a freezing cold start as a 5W30 would be in UK conditions, why is there a problem using 5W30 in the UK climate?
- Why is the concensus for a B4 rather than a B1 oil? I have read the ACEA specs and I note that B1 has (2.9<=HTHS<=3.6, sulphated ash <=1.3, evaporation loss <=15, total base number >=8.0) while B4 has (HTHS>=3.5, SA<=1.6, EL <=13, TBN >=8.0) and B5 has (2.9<=HTHS<=3.6, SA<=1.6, TBN<=13 and TBN >=8.0.) At present I only understand the implications of the HTHS figure, but these specs seem to confirm to me what I have read elsewhere, which is that B5 combines the fuel saving properties of a B1 oil with other properties of a B4 oil. Am I right in thinking that if the handbook recommends B1, and many people successful use B4, that I could use any of B1 or B4 or B5 oil grades?
- Do the updated recommendations from Honda (that I have read about) call for ONLY 0W30, and is that at B1 or B4 or B5 grade?
Oils I am considering at present are:
- Castrol Edge 0W30 B4 (common concensus, available over the counter),
- Mobil 1 0W30 B1 (available on Amazon, matches handbook exactly)
- Lubetech 0W30 B4 (recommended here, cost-effective)
- Mobil 1 0W40 B4 (available everywhere; within spec according to the handbook)
- Comma 5W30 B5 (likewise)
- Carlube 0w30 B5 (the closest to 0W30 B1 that is available over the counter locally)
- Fuchs 0W30 B1 (by far the most expensive of them all, matches the handbook exactly, said to be factory-fill oil)
Thanks for your attention, and again apologies for the long post.
