Hello,
Sorry for long post!
I have researched the similar issues with 7gen i-ctdi timing chain replacement where people mostly have higher timing chain whine after replacement (most of the reported cases) - with Original chain kit and aftermarket ones. It seems there is something else going on and no one to my knowledge have found nor reported the solution.
So my problems after timing chain kit replacement are much bigger than other peoples
Where do i even begin....
Firstly sorry for grammar, English is not my native language
So my car in question is Accord 2006 CN1 N22A1 stock engine no mods! - 540 000 km on the clock
So after timing chain replacement engine developed rough idle when cold and jerky acceleration combined with possible valve/lifter clicking/ticking noise which in some cases are so loud i release the gas pedal and accelerate slowly. Engine starts normal and when warm idle is good but i can hear inside the engine something is not 100% and to my ear it might come under section of the engine - oil pump chain not installed correctly?. Because engine starts fine and has power, so i ***ume at least timing chain is aligned correctly (i think). I have honda hds and did ECM reset with it, do reset the ECM because it is stated in service manual that after you replace any parts it needs to be done.
Copy from manual:
SEA5E24K72100000000BBAT10
So ECM reset made very little to no difference, problem is still there.
But the more i drive the better it gets. I have carefully driven almost 2 weeks now and last two days when engine is warm it is mostly ok, but not ideal! So no it is not fine.
I know it is near impossible to diagnose what is bad here. I haven't done the injector leak back test yet, but i will in couple of days.
Firstly i thought that there is oil pressure problem for some reason, so i installed oil pressure gauge to rule that out...pressure seems normal (compared numbers with manual - engine warm at 80C should read 820rpm idle 16psi and 3000rpm should read 59psi - my readings where point on correct). Why i thought it was oil pressure issue was because i found oil coming (small amount) form intercooler hose which travels from turbo outlet over gearbox to intercooler radiator. So the hose connection point
SO most likely injector problem? (HDS injector test, while idle, is all in norms, only nr 4 and 3 are 1.5-2mg off - but that should be totally in normal parameters because ECU/ECM will compensate that - correct me if i'm wrong) - i do not seem to find how to monitor injectors while driving with HDS so i could see what is happening while i drive. Can it be done with drive recording function?
Yes i understand that bad injectors will cause jerky engine while accelerating and valve noise, but i think there is something else involved here because in some point when engine is warm and randomly chain whine goes down the jerky engine also goes away (not 100% but lets say 80-90% - butt-dyno). Chain tension is done by oil pressure to tensioner so i think it is something to do with oil pressure.
Can it be that oil chain wasn't installed correctly? It needs to be aligned correctly (because balancing inside oil pump? ) - so question is what will happen if it is not aligned correctly (sprocket and oil chain)? Can it make engine behave like that? - BUT! If they managed to misalign those sprockets and chains then OMG they need to be blind because there is wayyy to many marks and colored chain links to miss that - but i am not surprised if they did.
YES i know you all roll your eyes and think why the hell haven't you taken the car back to the service place where the work was done? Answer is because the issue is intermittent and not that logical i wanted to check what is wrong with the engine myself before i take it back. I have spoken with the manager (he is family friend so all covered there ) - and we seem not to find the reason - he did all the work according to the workshop manual (at least he tells me that - hard to trust anything at this point...
So to better understand what was changed while in repair shop and what was changed by me before the repair shop:
BEFORE REPAIR SHOP by me:
New OEM Denso fuel filter
New OEM IMRC solenoid - i had P2004 come up and the cleaning the valve and whole intake didn´t fully resolve that error code - sure cleaning made it much much better but in some cases P2004 showed up and resolved totally after new IMRC solenoid.
Had no issues with the car except black smoke under hard accel and little black smoke while driving normally - most likely injectors or valve seals (but engine doesn´t burn oil tho, almost nothing so i ***ume injectors) will do compression test and injector leak back test and report back.
IN REPAIR SHOP:
Timing chain kit and oil chain kit:
(timing chain, timing chain upper sprocket, chain guides A and B, tensioning arm and tensioner - all original and correct parts) and oil chain, tensioner arm and tensioner, chain sprocket and also a timing chain and oil chain combo sprocket (sits on crankshaft). Lastly crankshaft balancing pulley also new and oem.
I used oem gaskets, hondabond ht and honda pro 1216E liquid gasket for chain cover and oil pan.
NB! Only difference with old and new spare parts were both chain tensioners - new ones are so called "free-flowing" ones which do not have that locking mechanism what doesn't allow tension to go off if there is no oil pressure, other that that they are same spare parts. All spare parts originate from Honda warehouse from Poland (i think this is central and biggest warehouse for Honda - correct if i'm wrong).
Also new OEM injector copper seals etc - basically all seals and o-rings needed to do that work and some extra.
New clutch kit with new dual mass flywheel from LUK (actually did a research, the LUK spare part was exactly same spare part honda uses, so i didn´t want to pay about 1200 euros for honda badged cartbox
Clutch kit was uprated 325 spare part not the original 315, other than that same spare part. Will not list all the other parts which was done with clutch system because i do not think it matters cuz not related with the problem.
So this post it not only for my problem but to all people who have the similar problem with chain whine after replacement (sometimes even louder than old chain). I would like to figure out what is the solution for that higher chain whine after replacing it. Like many people in internet have reported that official dealer shops also do not know what is the issue. Frustrating to say the least.
For summary what have i checked already:
Oil pressure - oil gauge installed
Oil filter - no problems there, but i still replaced it for good measure
will check compression and injectors leak back tonight when i get back home.
Any recommendations what more to check except injectors and compression?
Thank you all for you attention and help, if given
Copy from manual:
The inside ECM stores various specific data to correct the system even when there is no electrical power such as the battery negative terminal or No. 8 FI ECU (ECM) (15 A) fuse are disconnected. But stored data based on failure parts should be cleared by using the ‘‘CLEAR COMMAND'' of the HDS, if parts are replaced. |
IN REPAIR SHOP:
