Hi everyone,
I've already started another thread about the P0602 fault alone, but since a few additional facts have come to light, I thought it would be better to start a new thread covering both issues together, hoping to make the discussion more visible and easier to follow. I hope this doesn't go against any forum rules.
I'm looking for some advice diagnosing an issue with my 2007 Honda Accord 2.2 i-CTDi (CN1).
The car has a persistent P0602 engine ECU fault, along with intermittent starting issues. I've also got the VSA warning light on.
Initially, I thought I'd simply be able to clear the VSA warning, but after scanning the VSA module with my Foxwell NT510 Elite, I discovered a permanent fault:
66-01 – Brake Pressure Sensor Failure
The fault comes back immediately after attempting to clear it.
I've read about the known issue with the internal brake pressure sensor in the VSA modulator affecting some 2005–2008 Accords.
However, given that I also have the P0602 fault and intermittent starting problems, I'm wondering whether there could be a common electrical issue.
A few questions:
Any advice or first-hand experience would be greatly appreciated, particularly from anyone who has dealt with both P0602 and VSA 66-01 on the 2.2 i-CTDi.
Thanks in advance!
A few questions:
- Could the P0602 and VSA 66-01 faults be related?
- Are there any particular wiring connections, plugs, grounds or power supply connections I should inspect? If so, could someone point me to their exact locations? I'm not particularly experienced with car repairs, so even basic directions (for example, behind which headlight, under the bonnet or behind the glovebox) would be very helpful.
- I've heard about a potentially problematic wiring connector behind the offside (right-hand) headlight on UK models. Could this cause ECU or VSA-related problems?
- Does fault 66-01 generally indicate an internal failure of the VSA modulator?
- Has anyone successfully repaired the original unit rather than replacing it?
- If I buy a used VSA modulator, does it need coding, or is calibration and the appropriate bleeding procedure sufficient?
Thanks in advance!
