2012 CW3 2.2 Diesel Estate Tourer burning a lot of oil
OmniWalrus
Mk8 Tourer
As mentioned, I'm getting very high oil consumption on my CW3. I get puffs blue exhaust smoke on hard pulls in first (say at a junction trying to pull into a gap). I'll sometimes get sustained blue smoke after a long motorway drive. Once had it billowing blue smoke after pulling off the motorway, after pulling over and topping up the oil and letting it cool for about half an hour the blue smoke stopped.
At this point, if I make any long drive I know I'm going to be blowing blue smoke when I arrive and I'm going to need to top up the oil. I'm really hoping I don't need a rebuild and there's something else that may be an issue beyond piston rings.
I'm running the recommended 5W30 oil, could it be the brand I'm using? This one specifically -> https://drbcarspares.co.uk/products...-5ltr-engine-oil-for-petrol-and-diesel-atn005
150,000 miles
A history of neglect (oil I pulled out of it was sludge (there was no real service history))
1 owner before me
Then it could be advanced wear anywhere inside. You might find changing the oil again is the cheapest way of improving things, or not (£50).
It will also give you a clue there are other issues if more sludge comes out.
I've already flushed as much of the sludge out as I could with an engine cleaner flush and an oil change, as well as replaced the turbo which had broken due to being full of sludge.
I'm mostly looking for suggestions on any simple fixes that could cause oil burning on this engine before I start thinking about valve stem seals and piston rings.
