Paul S said:
Is it possible to install diesel drive shafts to the petrol models? I imagine they are beefier due to the turbo diesels torque.
When you take into account the gearbox and diff, the torque in 1st gear on the 2.2 diesel is about 20% more than the torque in 1st gear on the 2.4 petrol. The same is true for the 2.4 petrol relative to the 2.0 petrol. (EDM Accord)
I've done a spreadsheet using the same engines and chassis as in #4, screenshot below
I've used parts of the torque curve for each engine that can be approximated to a constant number
2.0 (K20A6) = 180 Nm 3k-6k rpm
2.4 (K24A3) = 220 Nm 3k-6k rpm
2.2 (N22A1) = 330 Nm 1.5k-3k rpm
The total torque at the shaft at wide-open-throttle, for each gear, is in the final column
Note that it's only in 1st and 2nd gear where the torque on the driveshafts is higher on the CN2 than on the CM2, once you reach 3rd gear and above, the torque on the driveshafts for the CM2 and CN2 are roughly the same.
Note also that the max shaft rpm is the max engine rpm divided by the total ratio, so 1st gear
2.0 = 6800 ÷ 15.6 = 417 rpm
2.4 = 7200 ÷ 15.5 = 465 rpm
2.2 = 4500 ÷ 12.9 = 349 rpm
which means that the CN2 has to change up before the CM2 (hence losing torque at the wheel sooner)
