alloy36
Hi all,
Bought my first accord yesterday and absoloutly loving it. However the car is slow/hesitant to start in the morning or after its been warm.
As I was driving it home, i pulled into a filling staion for some diesel. When I tried to start it up again it took about 4 seconds of the engine turning over before it started. It does ths everytime hot or cold. Otherwise the car is vry clean. It has done 88,000m and is the sport version.
I took it in to my mechanic this morning who diagnosed it as a weak battery. However, when i went to get a new battery the motor factors did a free battery test and said the battery was fine. I took it home to be sure connected the battery to my brothers 2.2 diesel merc by using jump leads. It was the same. so i guess it isn't th battery what else could it be?
Once started the car drives beutifully and will pull strongly through all gears and everything works perfectly. But as soon as i stop and restart it takes a while.
What else could it be?
There is no engine management light on. my mechanic told me if it was one of the sensors or a fueling problem the engine management light would come on is this true?
Also noticed that the engine temperature needle is always slightly below the midpoint on the guage even aftter a 20 mile drive. Is this normal? I always thought that all engines once warm are upposed to be at the centre of the guage,
Fahad - where abouts are you mate? I'm definitley interested in a remap once I sort this minor issue out.
Thanks all.
Thanks all.
