traderbob
Hi All,
I recently had a friend swap out my N22A1 engine (con rod through the case).
Since he has replaced I have an ABS fault and no readings from both wheel sensors - would it be possible that there is just a loose plug connecting the rear sensors to the wiring loom under the bonnet? if so where should I look/test.
thanks
Robert
thanks
Robert
