Hi guys, now after I been searching for what went wrong as this issue isn't new for tourer owner, but I just couldn't find something similar!
Ok, now the tailgate is forcing down when I open it from outside, normally when you just open it and pull it up it will then goes up itself, now it force itself down!! I have to use a long stick to support it from the ground instead I believe! as i use the boot everyday for what am doing.
When I press bottom from fob, tailgate beep as usual and slowly open as normal but when It reach to the top, normal will stop, this time 2 strange click sounds like something stuck, then gate fall back down itself slowly and auto shut as it should :-(,
I hope guy point me as I will try to sort thing out tonight.. Many thanks
Ray
Ray
