Thanks kow. I have tree pins on switch and do not know which one to bridge. One is red stripy next,yellow stripy and grey.
On the top , after shorting relay (same way as on the pictures on other thread) I got glow plug light flashing.
Looks like everything works except that switch.
Hi Tom, lucky for you, I have "watch topic" set on this old thread. The answers are
1. yes it is the sensor that's fauly
2. yes the system will need to be re-gassed if the sensor is replaced. If you do it yourself, take it somewhere to have the gas removed first, the gas is at high pressue and if you start to undo piping with it pressurised, I can ***ure you that if you're not wearing safety goggles, you could be blinded when you get it in your eyes.
Copying and pasting from post #36 in this thread ....
The aircon on the UK 7th gen petrol is much simpler than on the UK 7th gen diesel. (guys, don't confuse the two systems)
I think it's because they use the same system in the diesel throughout Europe.
The system on the 7th gen is actually a "climate control", which is very different from a bog-standard AC.
On a climate control system, the compressor will still come on intermittently even when the temperature is set to heat up the cabin in cold weather, because the evaporator will "pull" the huididty out of the air (and this neds the compressor to compress). The danger of this type of system in icy weather is that the piping can freeze up. On the diesel, the system can cope with this, but the UK petrol version will not handle clmate control in icy weather so well when the piping in the engine compatment is iced up. It will only work properly on the 7th gen petrol when the engine compartment has warmed up a bit in icy weather.
The pressure switch on the diesel is in a different position in the system from the UK petrol, and, it is a different sensor i.e. your car is a diesel, in which case the sensor is not a simple switch (hence the 3 wires). The sensor on the UK petrol is very simple, just a single on/off switch. Again, the diesel sensor is not a switch. Again, the system in the diesel is a defrost pump down, the system in the petrol is not.
For more info, read through this thread. http://typeaccord.co.uk/forum/topic/10382-diagnosing-aircon-problems/
cheers, Brian
