Channel Hopper
Another thread on the replacement and setting up of a replacement ABS/VSA pump (ATE 60) in the Gen 7 tourer (diesel).
This was an eBay purchase, the only one in the UK (the other was in Lithuania) and was it seems a bargain at just over £70 delivered.
The auction stated 'fully working' and since fitting the VSA light has gone out, but the hazard light still remains. I am checking to see if I have screwed something up but with the main warning light out at least I can relax.
Two codes have appeared after reconnecting the battery
(2-6) which I can clear with the wire across pins 4 and 9, and
8-4, which remains after clearing down.
I will post images later of the dismantle, but I was able to remove and replace with the headlight and bumper in place, done by taking the additional bracket under the module at the same time, which is actually rather easy. Total time including topping up the fluid and short test run - three and a half hours from a standing start.
I think I will still have to bleed the brakes unless a period of rest pushes the air back up the pipes.
So, what is the code above ?
