Anyone kind enough to help with a fraudulent and substandard VSA repair
taccoman
Accord Diesel
Hoping maybe to get lucky with someone with professional stationary that could help prove I've suffered a fraudulent and substandard repair for the VSA modulator on my Honda Accord 07 Diesel.
So far I've gathered
Afaik a separate brake pressure sensor does not exist on this model (its in the VSA modulator and there is no separate sensor) which is what I had believed initially but garage then convinced me to pay for an apparently non existent dealer part of an external 'brake vacuum pressure sensor' before offering to replace the VSA modulator which is what I had repeatedly asked them to do. I'm not sure if anyone is able or willing to give me something tangible I can action to claim against them as it appears they have billed for work they couldn't possibly have done!
After the apparently non existent external 'brake vacuum pressure sensor' was changed they then charged me for a reconditioned VSA modulator which is what I asked for initially and expected. It now appears however that although they have replaced it (botched with a leaking cross threaded flare nut) they have not used a reconditioned unit and instead provided a very old unit with faded German text on it. Apparently legitimate reconditioned units have a new warranty sticker which should be recognizable to those familiar with the work. I have gathered thus far this unit is more than likely from the batch that had the known manufacturing defect on them which was subject to the recall / extended warranty and which presumably means it will go wrong sooner rather than later. Again not sure if anyone with expertise & professional stationary or whatever would be willing to provide something?
Ignore this bit appears it was a red herring as this grotty label was apparently a new warranty label and German writing is something they put on their labels rather than anything from the original manufacturer.
Anyway here's hoping there are still some honest people left in the world and that the UK will not just descend into a who can screw who the most society because it's impossible to prove when someone has done something wrong!
The text on the antique looking VSA modulator I could make out so far is' warranty void if opened' and the German equivalent below, not sure about the top line.
The VSA diagram from the ESM for the CN2 does appear to show the brake pressure sensor as being part of the modulator and no external sensor is referenced. Seems like why would they need 2 anyway, recipe for confusion via conflicting readings and messy fault diagnosis increased manufacturing complexity and costs etc.
What I think might be true is possibly some model variants may not have had VSA as standard and those possibly had an external sensor. Of course this could be deliberately used as misinformation if you fail to quote all the qualifying details like the applicable model variant. Again as far as I can tell VSA was standard on CN2 and hence no external sensor.
Also now given how casually the garage has fed me a pack of lies and done bad work I'm wondering if that modulator is even the correct one for my car. The original had a clear code on it but can't see anything on this one and I'm guessing these need to be set up for the weight, wheel base and applicable brake system for the model variant. Question is how to tell if this was for a saloon / petrol model or whatever given I can't see any code on the modulator?
No it's not an issue at the moment. It seems they have used a made up part and then done the actual repair on top of that to cover it up, just they also did the repair badly. Maybe I can still dispute it without a statement from someone but having a statement from a Honda expert would obviously be very helpful.
After some research it does look like the warranty label may be legit, its just in a awful state. Its looks like the scam tactic was to hide the non existent part with the repair they were supposed to do in the first place. This is apparently something that some unscrupulous garages do because any casual investigation would conclude the work has been done and potentially miss that part of the job was bogus. The issue with this tactic is it would be easy to go off half ****ed and say they maybe didn't do any of the work they said they were doing and then you would end up looking stupid and having to take it all back so they do part of the work to avoid any obvious easy to win dispute with them and maybe make you look bad if you try to contest the wrong thing.
DTC troubleshooting code 66 in the Honda ESM shows the only step is to replace the VSA modulator it doesn't reference any other sensors or systems at all. Of course the garage will doubtless try to claim it had every other code under the sun to confuse things. Personally speaking I recorded code 66 using the blink code and only saw that code as being relevant but if anyone was likely to listen to me I'd have a refund already.
Since you have mentioned the marque, was it a Honda garage that you took it to ?
If not, was the mechanic that worked on the car trained at a Honda workshop ?
No, the issue was finding a garage to do it in the first place, this garage would not have been first choice if I had initially found any better reasonably priced ones on offer. My understanding at the time was Honda used to charge about 2k for the repair and that due inflation prices have probably gone up. Of course more recently I read maybe they can do it cheaply now (unconfirmed) but if so not much use for me to know right now.
I phoned through a list but some didn't answer me and others said no to Honda repairs, seems modulator repairs have become specialist work over the years. I got the impression that the garage I used is better at cheating people than they are at repairs. I think they know exactly what they can get away with and how to cover up for obvious accusations of fraud and breach of contract. Disputing a repair where it has apparently been done OK at the time but it comes to light later that there were issues such as phoney part replacements alongside legitimate work is a nasty tactic as it becomes hard to prove without an official statement from a reputable Mechanic or garage.
