morpheous87
Hello,
recently I bought my Accord 7th gen. My brakes are not in perfect condition and need some parts changing. I'm thinking about instead of buying OEM brakes parts to buy big Brembo brakes. My aim is to buy really big brakes for my Accord
So for front brakes:
- change front rotors disc from 300mm to 320mm (from 8th gen may be)
- Brembo 6 pot calipers 17z - like these ones
I will need some calipers adaptor to install them, probably I will find workshop for custom made, because I'm unable to find some on the market.
For rear brakes:
- Change current 260mm rotors to 300mm (stock front discs for 7th gen)
- Change the calipers to 4 pot Brembos like these:
Again custom caliper adaptors will be needed.
My concern is: will the OEM brake fluid pump work with these calipers? Will some modification needed ? Also will the ABS work fine it them?
Cheers!
For rear brakes:
Cheers!
